Far to the South-West:
Sterling had been walking through the thinning trees for almost a half hour, noting how they looked wilted, singed, and there was the occasional deep crater where something had obviously exploded. The entire forest edge smelled of death and battle and it stung his nose. There were places with blood, where the smell of death was stronger, where people had obviously fought. There was a constant echo, like distant thunder, of large explosions far off ahead that never seemed to stop. It made him wonder what the war described to him by the dying man in the tent was really like. Even that description hadn’t prepared him for what he saw when he came to the last edge of the trees.
His higher vantage point afforded a full view of the battle lines and even from the distance he was from them the extent of the devastation and scope of the front was incredible. He stood absolutely still, his eyes darting from place to place, taking in the chaos and destruction. It was so vast, so complete, that he even stopped breathing.
Long lines of trenches stretched off to the horizon, several layers on each side. All vegetation from the place he stood to a mile or more past the other side was gone, burned and blasted to bits or shredded unrecognizable. Craters and wreckage littered even the open ground behind the trenches. And between them was a chewed and scorched wasteland that varied from hundreds of yards to almost a mile wide at points. Broken barbed wire, wrecked machines, pieces of shattered rock, and the dead or what was left of them, left to the cruelty of the conflict because it was too dangerous to try to recover them.
Back from the lines, out of range of bullets and usually from the other side’s heavy guns, huge batteries of artillery were set at key points. Larger, heavier, guns than he’d ever seen, that fired with reports like the blow of a god’s hammer. He watched the shells they fired as they arced over the field and landed blowing even more gigantic holes in the land and spraying death with not only metal and fire but very often a haze of vapor and gas.
His eyes looked up from the incalculable destruction on the ground and saw another wonder; flying machines. Dozens of them. Men in machines that looked like strange kites, kites with guns, spiraling and fighting in the air above the long lines of trenches. Bright and complex colors showed on their wings and tails, some on the entire craft, as they turned, spun, jousted, and dove. Fire would erupt on one, smoke pouring from the engine, and the craft would spiral down to the ground and come apart in a shower of pieces. Others would take damage and flee. Still others, their driver killed, would almost lazily dive down to be destroyed by the ground.
He looked down at the lines again, his attention drawn by a large movement.
Thousands of men poured from the trench on the far side as a large barrage of explosions rocked the near trench, artillery shells landing every second for almost a full minute. The men charged, every one of them screaming, shooting their rifles toward the enemy. It was glorious.
Then the closer trenches came to life. Even as the artillery rained down on them the men began shooting at the oncoming wave of soldiers. Two fortified positions on the trench that had not been blown into the next world by the raining shells blazed to life, the guns in them firing at an unbelievable speed. Machineguns.
The rushing attack of soldiers began falling, dying by the hundreds, as the hail of rifle and machinegun bullets tore into and through them. With no cover in the blasted wasteland between the trenches, slowed by the broken ground and tatters of wire, they stood no chance. To make it worse, as the attacking artillery stopped the defending artillery began, shells falling into the fray and blasting the attacking wave. Bodies were shredded, blown to pieces, torn, and destroyed.
The attack faltered, then broke, and the men began to run back toward their own trench line without even getting two thirds of the way across the field.
But the defenders kept firing, cutting them down as they fled. The shells still rained down, killing more. Until at last only a quarter of the force that began scrambled, bloodied, into the relative safety of their own trenches.
Sterling just stared, almost hungrily, and thought it would have ended there but it didn’t. The distant voices in his mind laughed.
The defenders counter-attacked. Another wave of men, this time going the other direction, poured out of the trenches and began running toward their enemy just as the others had before.
And they met the same fate.
The entire process took nearly two hours and after it was done neither side had gained even an inch of field. The flying machines were long gone from the sky, returned to wherever they’d come from or reduced to wreckage on the ground. Thousands were dead and both sides were exactly where they’d began.
They’re insane, Sterling thought. The whole world has gone insane. And they said I was a monster.
He moved at last, shaking his head, and began walking toward the lines. His destination was far through the disaster before him on the other side.
“...you belong here...” the distant voices in his mind whispered. “...it is beautiful.”
“Shut up,” he growled, closing his eyes tight and clenching his jaw.
“So much food...”
He stopped for just a moment, breathing deep and focusing on his inner self, pushing the edge of the darkness back. The voices faded but the distant murmur of them was still there.
It was worse than before. It had only been a day and they were back when last time it had taken a week after he’d awoken. It would take energy to keep them quiet, to remain hidden. Perhaps it was the chaos and destruction before him. Perhaps it would just continue to grow worse the longer he lived until it consumed him completely. Whatever the case he still had to continue on.
He walked toward the rear line of trenches as the red-tinted dusk began to grow.
