Forum Clock messed up?
Got a suggestion for the site? For the forums? A feature not working the way it should? Well here's where you report it and it will get looked at.
Postby David Kain on Fri May 02, 2008 4:45 am
I have my forum time set to Eastern Standard time, but the forum says it's 7-something AM when it's 1:51 PM, what's up with that?
User avatar
David Kain
Shifty Novice
Shifty Novice
Re: Forum Clock messed up?
Postby ReedBooth on Fri May 02, 2008 3:01 pm
I'm still trying to figure this one out. As soon as I can get my local time I'll let you know what time delay wil be apropriate.
-B
The loudest sound at the firing line is 'Click'.
"The Fountain(F. Steve Wilson)" - Pendulum
User avatar
ReedBooth
Shadow Shifter
Shadow Shifter
Postby ReedBooth on Fri May 02, 2008 3:04 pm
Allright, i'm running -1 on european standard time and it is accurate for me in the Unites States. What I would suggest is take the time your post occurs, add or subtract when it is supposedly accurate, and pick from there in your user CP.
It's phpBB. It's not supposed to make sense. :)
EDIT : It's slow by about 8 minutes for me right now, but I figured that's close enough.
User avatar
ReedBooth
Shadow Shifter
Shadow Shifter
Return to The Gearbox
Who is online
Registered users: No registered users
cron
